TwinTurbo.NET: Nissan 300ZX forum - I wouldn't be flogging it while it's cold
300ZMang
on January 15, 2014 at 9:40 AM
my z runs like crap after warm up. ...any clue ?
posted by BlackTwins
on January 15, 2014 at 01:49 AM
And once it's warmed up, perform the heated o2 sensor test. That will tell you if they're operating as they should.
Could also check the MAF and Engine Temp sensors.
BlackTwins
01:49:15 01/15/14
I wouldn't be flogging it while it's cold -
300ZMang
09:40:06 01/15/14
Have you checked the ECU codes? (n/m)
SammybTT(TN)
11:10:55 01/15/14
Re: Have you checked the ECU codes?
BlackTwins
19:56:59 01/15/14
http://z32.wikispaces.com/ECU+Diagnostics
SammybTT(TN)
21:26:03 01/15/14
Go to Auto Zone. But better to DIY. ECU on passanger>
ZUL8TR
06:22:31 01/16/14
I thought Auto Zone can only read OBD II? (n/m)
300ZMang
10:23:16 01/17/14
Re: I wouldn't be flogging it while it's cold
BlackTwins
19:58:20 01/15/14
Had a similar problem years ago
Turbodog (CT)
16:01:27 01/15/14
Re: Had a similar problem years ago
BlackTwins
19:56:16 01/15/14
forgot to add, ran good when cold but as it warmed up
Turbodog (CT)
16:04:28 01/15/14
Re: forgot to add, ran good when cold but as it warmed up
BlackTwins
19:59:03 01/15/14
Inside the fuel tank on top of the pump (n/m)
Turbodog (CT)
18:21:19 01/16/14
