TwinTurbo.NET: Nissan 300ZX forum - Pop your hood and rev the engine up from under there are try
Subject Pop your hood and rev the engine up from under there are try
Posted by BeefEaterZfro on January 14, 2014 at 6:17 PM
  This message has been viewed 196 times.
In Reply To burnt rubber smell in full boost posted by wh0sjeff on January 14, 2014 at 04:32 PM
Message and locate where the smell is coming from. If you're fairly sure it's not the clutch, and don't see/smell anything from under the hood, I would definitely check the entire length of the exhaust system. Something rubber/plastic could be getting to close. Are all your wheel wells secured? Under a hard pull air could be pulling them into the tires. Just some ideas. Let us know what you find.
