TwinTurbo.NET: Nissan 300ZX forum - Mounting boost solenoid under nose panel?
Subject Mounting boost solenoid under nose panel?
Posted by wild_maxx on January 13, 2014 at 6:10 PM
  This message has been viewed 248 times.
Message Previously I had my Greddy boost solenoid mounted near the cruise control module but I'd like to relocate it under the front nose panel. I've run both Wastegate lines and solenoid wiring up to the nose but I'm not sure on a good way to run the boost/vacuum source.
I have the Z1 2.5" piping kit and it has the pressure ports coming off the TB inlet pipe but they are facing the engine. I tried running a 6mm line from there back up to the nose. It it makes a 180* bend which usually kinks the line.
Could I use the original vacuum source for the Recircs from the balance tube and left side of the plenum for my boost solenoid and run new lines to the recircs? Or better yet... Could I T into each line and use a single source for each side? Meaning run a 6mm line from the balance tube and T into it for the recirc and boost/ vacuum and the same for the left side for the boost solenoid?
