TwinTurbo.NET: Nissan 300ZX forum - Re: might be caused by the ECU
Subject Re: might be caused by the ECU
Posted by pfitzgerald on January 08, 2014 at 8:19 PM
  This message has been viewed 316 times.
In Reply To might be caused by the ECU posted by zromtech on January 07, 2014 at 03:07 PM
Message Update hopefully someone can confirm my findings
I hooked up a test gauge to fuel pressure and took it for a drive. Problem is directly related to fuel pressure. Upon the loss of power my pressure dropped to 23 then if I parked and idled it would slowly come a bit back up
I bypassed the fpcu and took it for a drive. The fuel pump was working extra hard ( based on sounds) and struggled bad. Pressure dropped to 17 and only came back up to 20 on idle.
My assumption would be that it is my fuel pump and that bypassing put extra stress on it and killed it a bit more. It's very noisy even as idle .
Do I sound correct or does anyone have any other suggestions before I drop a bunch on a new pump?
