TwinTurbo.NET: Nissan 300ZX forum - Vacuum Leak Trick
Subject Vacuum Leak Trick
Posted by ThisIsSparTTa on January 08, 2014 at 12:57 PM
  This message has been viewed 321 times.
In Reply To Just moved to Phoenix and Barely Failed Emission Test! posted by mfergus2000 on January 08, 2014 at 12:16 PM
Message Off the balance tube, run a vacuum tube with a T. On one side of the T have the vacuum hose go down a bit, and left open. This will create a vacuum leak, which will lean you out, which should allow you to pass. Lots of people have done it. I passed emissions first try with that and I have high flow cats.
