TwinTurbo.NET: Nissan 300ZX forum - Grounding and power supply issues come to mind. Starters
Subject Grounding and power supply issues come to mind. Starters
Posted by jzack on January 06, 2014 at 7:12 PM
  This message has been viewed 220 times.
In Reply To 1990 300zx TT having starting issues. posted by FilterEffectTM on January 06, 2014 at 05:51 PM
Message take a lot of DC current (amps) to turn over. Corrosion on the battery terminal connections (even if they look good), issues with the battery to body ground cable that's right behind the battery (wire known to frey at the body lug behind battery), starter +12v wire not connected securely, etc.
Need to check all these things out - fairly easy to do. It's also possible the ignition switch has gone bad but check the other things first.
PS - If starter installed was a rebuilt (and not brand new) that could be the issue too?
