TwinTurbo.NET: Nissan 300ZX forum - Re: Need some help on a O2, Idle issue.
Subject Re: Need some help on a O2, Idle issue.
Posted by hopester on January 06, 2014 at 1:25 PM
  This message has been viewed 248 times.
In Reply To Need some help on a O2, Idle issue. posted by Woody75 (Denver) on January 05, 2014 at 09:44 PM
Message I have a few ideas. From personal experience, I had to replace the I.A.A. unit due to idle issues on my car. Both solenoids tested good per FSM. The idle issues could be a symptom of non working O2 sensors.The other idea I have is about the wiring to the O2 sensors. You could have continuity in the harness but have a fault, like a ground between the O2 sensor and the ECU. That could cause the voltage from the O2 not to make it back to the ECU. The 15* timing on a cold engine could be a bad engine temp sensor. FSM says a bad engine temp sensor assumes the engine is warm once the engine is running. EF&EC-34. I am just sooting some ideas out, I hope this doesn't send you on a goose chase. You are way more experienced than I am at working on these cars, good luck!
