TwinTurbo.NET: Nissan 300ZX forum - No air leaks, did the tests for that.
Subject No air leaks, did the tests for that.
Posted by Woody75 (Denver) on January 06, 2014 at 9:28 AM
  This message has been viewed 230 times.
In Reply To Sounds like their is an issue with the idle valve, or the posted by ZaXxon on January 06, 2014 at 08:44 AM
Message I thought the idle valve was toast as well. That's why I removed it. The smaller solenoid (blue connector) was garbage and not working so I put a good/tested one on. the other larger solenoid is testing out and working fine per the fsm tests. Unhooking the connections while the car is running I can hear the solenoids click and hear changes in the air flowing through it. But turning the adjuster does nothing. I may need to change out the larger of the 2 solenoids for the hell of it just for piece of mind that it is good.
All connectors are good, I even replaced them as they were both broken and made sure the wiring was good and connected afterwards.
The other valve that connects closer to the balance tube is brand new as well as the owner had it replaced.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
