TwinTurbo.NET: Nissan 300ZX forum - Re: loss of power
Subject Re: loss of power
Posted by type993 on December 30, 2013 at 2:07 PM
  This message has been viewed 200 times.
In Reply To loss of power posted by Koppz32 on December 30, 2013 at 01:01 PM
Message Start cheap and familiarize yourself with the FAQs this on ANY Z site. Injector failure is ubiquitous with these cars, there are plenty of methods available to diagnose a failed injector.
Are the injectors OEM? Re manufactured? What condition is your injector subharness in?
Check out Robo's page on diagnosing the potential injector problem:
[ http://www.twinturbo.info/63104/159859.html ]
It would be more helpful if you could post a vid of the pump sound (most describe it as a constant whine) so people have a better idea of what you're dealing with. There are multiple conditions that can present symptoms similar to a failed injector. Use the link above (I recommend the multimeter ohm test) and check for corrosion on the injector connectors before spending money. Also, do a lot more clicking/reading on this site. It has been years since I've seen a completely unique problem.
RT
______
Royce
1991 Super White Z32 TT
