TwinTurbo.NET: Nissan 300ZX forum - had same symptoms, was the gauge cluster
Subject had same symptoms, was the gauge cluster
Posted by Danny(Austin) on December 28, 2013 at 2:30 PM
  This message has been viewed 330 times.
In Reply To speedometer going crazy posted by Agent X on December 27, 2013 at 01:26 PM
Message Since you've had yours checked, may as well try a known good cluster and speed sensor to rule those out. I had a similar issue in my 97 maxima, replaced the speed sensor, and it again was the cluster.
In the Z it went from sporadically bouncing needle to eventually no movement and the power steering would be disabled at times. Would check out the connectors going to the cluster as well.
