TwinTurbo.NET: Nissan 300ZX forum - could be speed sensor or speedo
Subject could be speed sensor or speedo
Posted by ThisIsSparTTa on December 28, 2013 at 8:57 AM
  This message has been viewed 332 times.
In Reply To speedometer going crazy posted by Agent X on December 27, 2013 at 01:26 PM
Message Its not clear from your info right now because the speed sensor routes eventually to the speedometer then over the ECU/HICAS as a digital signal. Power steering and cruise control will be messed up if they get a bad signal.
Thankfully the FSM has a procedure to check the speed reading manually with a multimeter. Can't pull it up right now because I am on the phone.
