TwinTurbo.NET: Nissan 300ZX forum - Power Steering Return Line Rubber Hose Replacement
Subject Power Steering Return Line Rubber Hose Replacement
Posted by zman03 on December 27, 2013 at 5:12 PM
  This message has been viewed 242 times.
In Reply To Re: Power Steering Return Line Rubber Hose Replacement posted by Stadsport (Nick@CZP) on December 27, 2013 at 10:01 AM
Message Thanks. I got it. I ended up taking a free blade hand hacksaw and made two cuts down opposite sides of the crimp connector. I cut it just enough to penetrate the metal part of the crimp. Then I split the crimp connector by wedging a screw driver in both halves of the connector to get it loose enough to brake the bottom collar. It was a fairly tedious operation with the limited space but successful. It turns out there is no barb on the pipe. It's just straight but has a bottom collar. I was able to do the cuts without nicking the collar so a new hose should seal around the collar. I have pictures but not sure how to upload them.
