TwinTurbo.NET: Nissan 300ZX forum - Good advice... alos have a look though these:...
Subject Good advice... alos have a look though these:...
Posted by Medallion Man on December 27, 2013 at 3:08 AM
  This message has been viewed 178 times.
In Reply To Fuel pressure is easy to check. Make sure the MAF is posted by zellamay on December 26, 2013 at 03:36 PM
Message the standard this to do is to check all connectors for corrosion and good contact including the battery terminals and earth points. Also worth checking the connector for the ecu and all the fuses (all three fuse boxes), pull them one by one and use a meter, do the replays as well.
Make sure you have the right size battery.. if you food it, it won't start!! you'll need to pull the fuel pump fuse and turn it over until you clear it.
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=922678 ]
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.335 ]
[ http://zhome.com/ZCMnL/PICS/hesitation/hesitation.html ]
