TwinTurbo.NET: Nissan 300ZX forum - The FPR is boost/vacuum referenced
Subject The FPR is boost/vacuum referenced
Posted by -Grimm- on December 26, 2013 at 4:36 PM
  This message has been viewed 199 times.
In Reply To Re: 43.5 psi above intake manifold pressure. posted by iamdan012 on December 26, 2013 at 04:23 PM
Message It is ~44 psi plus the intake pressure
If you have 10 psi boost, you should have (at that boost) ~54 psi fuel pressure.
With the car off there is *no* fuel pressure, but the check valve in the fuel pump should maintain a little bit of pressure.
If the pressure is ~40 at idle and drops to 0 immediately, something is not correct. Could be the check valve, could be the regulator and pulse dampener, or could be a leaky injector seal
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
