TwinTurbo.NET: Nissan 300ZX forum - Fuel pump/controler going bad?
Subject Fuel pump/controler going bad?
Posted by sky z on December 22, 2013 at 10:59 AM
Message Some days ago my car have start to make +12 AFR on WOT
it was running fine at 11.5 AFR and i log the nistune and the target AFR is around 11.3, also log some runs all the other sensors( MAF etc) are fine.
Injectors, fuel filter, fuel damper is new.
The fuel pump/controler and regulator are stock whit around 93k miles
On cruise it runs fine around 15 AFR,
On part part throttle also runs fine around 13s
The TT fuel pump controler are 3 speed flow, is it possible the controler is bad only when it need max flow? or is the fuel pump that is dying?
tks for any advice!
