TwinTurbo.NET: Nissan 300ZX forum - Main bearing clearances need to be in spec on the tt crank
Krazyd27(Houston)
on December 17, 2013 at 4:11 PM
Na and Tt block differences
posted by 1995z32tt
on December 17, 2013 at 03:57 PM
Going in the Na block. oil filter tree check valves need to be plugged, and you need to use a tt oil pump
1995z32tt
15:57:13 12/17/13
Main bearing clearances need to be in spec on the tt crank -
Krazyd27(Houston)
16:11:02 12/17/13
Will it bolt up, yes
-Grimm-
16:19:01 12/17/13
fyi, no difference btw na and tt cranks
ZXoltan
07:40:06 12/18/13
