TwinTurbo.NET: Nissan 300ZX forum - TPS can be checked and replaced easy...
Subject TPS can be checked and replaced easy...
Posted by Medallion Man on December 13, 2013 at 9:31 AM
  This message has been viewed 146 times.
In Reply To Re: This belongs in TECH but check and clean your TPS & CAS posted by Deanos01 on December 13, 2013 at 09:08 AM
Message have a look at these...
TPS..
[ http://z32.wikispaces.com/Throttle+Position+Sensor ]
and good guide
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.221 ]
like advised above, clean all connectors (be careful not to damage them or loose the clips), don't forget the MAF one under the head lights panel, also check (and clean connectors on) the ING COIL relay in the engine bay fuse box. (same colour ones can be swapped)
good guide to keep it right
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=922678 ]
and
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.335 ]
and
[ http://zhome.com/ZCMnL/PICS/hesitation/hesitation.html ]
and this is the Z bible..
[ http://z32.wikispaces.com/Factory+Service+Manual ]
