TwinTurbo.NET: Nissan 300ZX forum - I'm not sure of any 'best' break in practice
Subject I'm not sure of any 'best' break in practice
Posted by -Grimm- on December 11, 2013 at 10:35 AM
  This message has been viewed 190 times.
In Reply To Re: It wasn't the 'hard break in' posted by MaxxAction on December 11, 2013 at 10:22 AM
Message But I have always heard that you break in the cams (yeah I work on old cars, so this doesn't have to be done for the Z), change the oil, then do around town driving for ~500 miles.
The rings need acceleration (pressure) to force against the wall and "file" themselves to the cylinder shape, then vacuum (deceleration) to clear away the metal debris (which is minimal).
That's why around town driving works best.
Also, did you use conventional oil? as Synthetic will prevent the friction that lets the rings seal to the cylinder walls.
And lastly...
12. 700-900 mi, Started pushing up to boost limit @ 6 PSI. In general was running well, with a couple more troubleshooting things tackled.
13. 900 mi did timing belt and other various work. Starts weird behavior
That should signal something to you immediately. What are 'various works', and is there a chance the timing was set incorrectly?
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
