TwinTurbo.NET: Nissan 300ZX forum - Seems strange that two injectors would fail at the same time
Subject Seems strange that two injectors would fail at the same time
Posted by SammybTT(TN) on December 10, 2013 at 10:07 PM
  This message has been viewed 186 times.
In Reply To Injector Ohm Question posted by 91tt on December 10, 2013 at 04:46 PM
Message I am sure you have double checked your readings and verified your meter is functioning properly. Also not hearing them fire is a good indication. Hate to hear you having this issue. I will also be looking into the injector power modification in the very near future. I recommend that you use a dremel tool to allow access to your injector cap head bolts when you remove it. I saw the write up on this forum. This allows you to remove the injectors without removing your plenum. Good luck resolving your issue.
