TwinTurbo.NET: Nissan 300ZX forum - New connectors fitted with Sards...
Subject New connectors fitted with Sards...
Posted by zx299 on December 10, 2013 at 5:51 PM
  This message has been viewed 129 times.
In Reply To Re: Injector failure ???? posted by ZUL8TR on December 10, 2013 at 05:53 AM
Message and no corrosion was present on wiring harness. The injector seems to be working electrically (12v, ecu signal + clicking), and an ohms test on the injector coil is okay. It just seems that no petrol is getting through.
I have spark so no point in swapping coilpacks.
I won't dremmel the plenum because the Sards use a collar to fit. It's simpler (and safer) if I pull the plenum
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
