TwinTurbo.NET: Nissan 300ZX forum - Re: Injector failure ????
Subject Re: Injector failure ????
Posted by ZUL8TR on December 10, 2013 at 5:53 AM
In Reply To Injector failure ???? posted by zx299 on December 08, 2013 at 03:45 AM
Message Check the condition of the wires for corrosion. When I replaced high omed and failed injectors to 93+ type I found green corroded wires when redplacing the connectors. Corrosion increases resistence with amp load.
Switch out bad cylinder with a coil another coil to test.
If you pull the plenum dremel it for no plenum pull in the future.
ZUL8TR in Orlando,FL
