TwinTurbo.NET: Nissan 300ZX forum - that isn't right
Subject that isn't right
Posted by aliaZ on December 08, 2013 at 5:42 PM
  This message has been viewed 241 times.
In Reply To Re: Is my rebuild borked? Ideas, please posted by MaxxAction on December 07, 2013 at 04:02 PM
Message :That isn't enough compression for the motor to run. You need at least a hundred pounds of compression to create combustion from what I understand.
You understand incorrectly. If that was the case, the engine wouldn't run at part throttle high manifold vacuum conditions when the dynamic compression ratio is far less than 100 psi
Is the throttle propped all the way open?
It doesn't matter if your throttle is open if the balance tube is off
