TwinTurbo.NET: Nissan 300ZX forum - If you are doing a compression test only, leave the cas
Subject If you are doing a compression test only, leave the cas
Posted by Krazyd27(Houston) on December 06, 2013 at 10:48 AM
  This message has been viewed 247 times.
In Reply To Yeah you can posted by -Grimm- on December 06, 2013 at 09:00 AM
Message unplugged. you'll fill the cylinders with fuel unless if you've pulled the green fuel pump fuse by the battery. Your symptoms sound indicative of a incorrectly installed timing belt or a cas that is misbehaving. but the compression results lead me to believe the timing belt was set incorrectly.
