TwinTurbo.NET: Nissan 300ZX forum - Can I run compression test while working on timing belt?
Subject Can I run compression test while working on timing belt?
Posted by ThisIsSparTTa on December 06, 2013 at 7:55 AM
  This message has been viewed 278 times.
In Reply To Confirm your timing belt is set correctly posted by ttsmokin on December 05, 2013 at 10:11 PM
Message Okay, not actually while working on it, but once I get it set, if it was out of position. Could I crank the engine for the compression test?
I'm thinking of this because if the timing belt is set correctly, I can save the hassle of putting it all back together if its going to ultimately get torn back apart. I think it would be okay, I might have to plug in the CAS and maybe the coolant temp sensor. I don't see any harm in turning it over without coolant on a cold engine.
