TwinTurbo.NET: Nissan 300ZX forum - The site 'rebuild' document is taken from
Subject The site 'rebuild' document is taken from
Posted by -Grimm- on December 05, 2013 at 10:27 AM
  This message has been viewed 835 times.
In Reply To Great point about double checking the work posted by SammybTT(TN) on December 05, 2013 at 09:57 AM
Message ...http://diy.icydesigns.com/article/183/Nissan/300ZX/Z32_(1990-96)/Engine/Engine:_Engine_Assembly/#.UqCl-tDTmUk
or vice versa
Either way, some steps are snuck in there, for instance, your transmission brackets:
Step 10: Install oil filter tree
Service Manual Reference: EM-6
•Install lower transmission brackets on both sides of the block.
•remove any old gasket from the edge of the tree.
•Check condition of the rubber O-ring inside the tree. (Image 24) This ring is not part of the rebuild kit, so replace separately if necessary.
•Install tree with new paper gasket from gasket kit. Torque bolts to 12-15 ft.lbs. (1.6-2.1 kg-m) (Image 25 shows mounting location on the rear passenger side of the block.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
