TwinTurbo.NET: Nissan 300ZX forum - Good luck. (n/m)
Good luck. (n/m)
ZXRider
on December 04, 2013 at 5:09 PM
The holes and the studs are perfectly aligned.
posted by JMartz
on December 04, 2013 at 05:07 PM
Help identifying wheel offset
JMartz
14:53:14 12/04/13
The 5x100 is the lug pattern
ZXRider
15:05:17 12/04/13
Wheels are currently mounted in my Z
JMartz
15:15:36 12/04/13
In that case it makes no sense
ZXRider
15:56:24 12/04/13
Likely a mistake of some sort.
JMartz
16:36:15 12/04/13
Can you measure the diameter of the stud holes?
ZXRider
16:42:01 12/04/13
JMartz
17:07:11 12/04/13
Good luck. (n/m) -
ZXRider
17:09:46 12/04/13
how much would you like for said rims? :3 (n/m)
Zvil (FL)
07:08:43 12/05/13
Re: how much would you like for said rims? :3
JMartz
07:04:29 12/06/13
The studs on the Z are 12mm
ZXRider
16:52:00 12/04/13
My Works GT-Cs are marked the same ...
DaZedMan
13:41:22 12/06/13
