TwinTurbo.NET: Nissan 300ZX forum - Re: Perfect!
Subject Re: Perfect!
Posted by revolutionary on December 04, 2013 at 12:14 PM
  This message has been viewed 372 times.
In Reply To Perfect! posted by -Grimm- on December 04, 2013 at 11:49 AM
Message I already have wiseco pistons and eagle rods in there ill give u the backround on the engine it was built by ash and tuned by him it ran perfect.
Then one day my ebc vacuum hose came off at the track and it ran open boost so it ended up messing up the head on cylinder number 5 air was getting through the valves when they were closed (bad detonation).
So i had a pair of never touched stock heads i threw my cams springs and valves in there and slapped it on the block then it was running fine again except i heard the slight tap barely touching the gas at 2800 rpm we all know what that is.
So now im pulling again but the point im getting at is the motor is well built but the accidental overboost is what messed up the bearing so its not like it just happened and idk why.
by the way that is a very helpful writeup that needs to be in faq!!!
