TwinTurbo.NET: Nissan 300ZX forum - Try another ECU.....
Subject Try another ECU.....
Posted by zx299 on December 03, 2013 at 12:06 AM
  This message has been viewed 227 times.
In Reply To cold start problems posted by slcZ32 on December 02, 2013 at 08:29 PM
Message The ecu should prime the fuel rail when the ignition is turned on. You are only priming when the engine is cranking (cas signal) so it appears you may have a software corruption in the ecu.
Fit a 'known' working ecu and that should fix your problem
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
