TwinTurbo.NET: Nissan 300ZX forum - cold start problems
Subject cold start problems
Posted by slcZ32 on December 02, 2013 at 8:29 PM
  This message has been viewed 297 times.
so, after noticing that my car will turn on when i feather the gas, i decided to see if there was any fuel pressure, or flow at all, so i unhooked the hose from the fuel pump to the fuel filter and turned the ignition on.... how surprised i was to see that no fuel flow at all,,,,and when i turned the key to crank the motor on, there was no flow either,,, so i noticed that fuel will come out from the hose when cranking the motor and hitting the gas at the same time.
do you guys think this is a fuel pump issue? or an electrical problem? please point towards the right direction
tnx
once that the car turns on it runs fine...
