TwinTurbo.NET: Nissan 300ZX forum - Cylinders 2, 4, 6 Fouling plugs & Fuel in Plenum
Subject Cylinders 2, 4, 6 Fouling plugs & Fuel in Plenum
Posted by Krazyd27(Houston) on December 01, 2013 at 12:35 AM
  This message has been viewed 329 times.
Message I found related articles on aus300zx. But nobody seems to know the root cause. The the motor was recently overhauled with Refreshed heads and block 120k, stock injectors. The only thing that was tampered with was the motor and a painted engine bay. Upon startup the motor ran Rough and kept shooting black soot out of the exhaust. I pulled the plugs to find 2 4 6 were all black and fouled and reeked of fuel smell. The plenum had fuel in it but mostly in the passenger side. cylinders 1 3 5 on the passenger were bone dry with clean plugs. I swapped the cas for a known good one with no success. I ripped apart the front end and re did the timing belt and have yet to finish reconnecting everything. I did relocate the PTU under the nose panel. The subharness was bypassed and soldered together. That's all that comes to mind. If you have any ideas let me know I'll check tomorrow after work. I only get a few hours a day to work on my z. Thanks in advance
