TwinTurbo.NET: Nissan 300ZX forum - Re: Also check all electricla connections for corrosion
Subject Re: Also check all electricla connections for corrosion
Posted by slcZ32 on November 29, 2013 at 12:25 AM
  This message has been viewed 118 times.
In Reply To Also check all electricla connections for corrosion posted by Medallion Man on November 27, 2013 at 02:41 AM
Message i have tried and checked most of the stuff on those links and found out that the yellow connector that goes hooked up to the temperature sensor, that CJw3 was talking about, was broken, i fixed the problem and re spliced the wire and everything is properly fixed in regards of that, however the problem still persists!!
i noticed that when i turn the ignition on, my fuel pump clicks but i dont hear it priming, is there a way to test it?>? any one knows another potential thing that could be wrong??
