TwinTurbo.NET: Nissan 300ZX forum - Get ALL the cosmetic interior trim off, and the outer
Subject Get ALL the cosmetic interior trim off, and the outer
Posted by Jkova300z on November 20, 2013 at 4:57 PM
  This message has been viewed 213 times.
In Reply To Need guide or tips for PS Window Replacement posted by ThisIsSparTTa on November 20, 2013 at 08:32 AM
Message plastic B pillar trim piece (the one that has the circular black hole cap in it). Unbolt the two bolts you speak of that attach the glass to the mechanical window slider. IIRC it literally slides out. Note: there are STOPPERS that are hard to see on the inside of the door skin. There are two I believe, and appear zinc plated, with 10mm nuts that hold them. You need to remove these (they are what holds the glass from coming completely up/ out. Does take some "finagling" but I never removed those joystick like swivling bolts with domed caps, and I don't think they should need removing. In all it should be pretty simple. Definately one of those jobs that seems harder than it looks. Don't forget to reinstall the stoppers, and adjust them so you get that nice solid door slam sound as it seals.
