TwinTurbo.NET: Nissan 300ZX forum - All the guides on the glass stay in place.
Subject All the guides on the glass stay in place.
Posted by Woody75 (Denver) on November 20, 2013 at 1:50 PM
  This message has been viewed 202 times.
In Reply To I was thinking that, but then there's the outer guide posted by ThisIsSparTTa on November 20, 2013 at 12:19 PM
Message For the guide on the pillar, you need to have the window down. Helps to remove the outside door/glass trim as well. Then you need to remove the black pillar trim on the outside of the car (plastic piece). There are push pins under the vertical seal on the pillar and 1 other kind at the bottom as well. Once removed or popped the trim will come off. Then you should be able to remove the glass and see anything it hangs up on. The seal by the mirror can hang it up as well. I usually undo it and pull it back out of the way.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
