TwinTurbo.NET: Nissan 300ZX forum - Checked clutch switch yes
Subject Checked clutch switch yes
Posted by spicyZ on November 20, 2013 at 11:45 AM
  This message has been viewed 220 times.
In Reply To Did you check your clutch switch on the pedal under posted by CmyZ on November 19, 2013 at 09:49 PM
Message Without it depressed, the starter relay doesn't trigger. With it depressed, the starter relay clicks, so it appears to be functioning properly.
Attempting to arm the system failed. Closed all doors, locked with the key and waited 1 minute. Reached through window, unlocked door. No alarm sound.
The handful of tests I did at the module passed, but you're right - swapping it out completely is probably a good next step.
Thanks!
-jb
