TwinTurbo.NET: Nissan 300ZX forum - The hood sensor switch is on a bracket that sometimes
zellamay
on November 18, 2013 at 10:30 AM
Re: Car won't crank after 60K
posted by Rasta420
on November 18, 2013 at 09:17 AM
bends down over time. All you have to do to fix it is bend it up a bit, to make sure the hood depresses the switch.
spicyZ
08:54:50 11/18/13
Rasta420
09:17:10 11/18/13
Re: Re: Car won't crank after 60K
spicyZ
09:30:00 11/18/13
The hood sensor switch is on a bracket that sometimes -
zellamay
10:30:20 11/18/13
Did you run power directly to the starter, and did the
zellamay
15:04:54 11/18/13
Did not run power directly to the starter..
spicyZ
15:14:58 11/18/13
Have you measured the voltage at the starter ignition
YlwPrlZTT
20:02:07 11/18/13
Which lead are you referring to?
spicyZ
08:36:37 11/19/13
Yes the actual ignition lead at the starter that energizes
YlwPrlZTT
15:03:32 11/19/13
Will get this checked
spicyZ
11:46:01 11/20/13
Did you check your clutch switch on the pedal under
CmyZ
21:49:10 11/19/13
Checked clutch switch yes
spicyZ
11:45:25 11/20/13
Was the security light on?
-Grimm-
11:52:52 11/20/13
Security light isn't working at all
spicyZ
12:28:34 11/20/13
