TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Car won't crank after 60K
Subject Re: Re: Car won't crank after 60K
Posted by spicyZ on November 18, 2013 at 9:30 AM
  This message has been viewed 222 times.
In Reply To Re: Car won't crank after 60K posted by Rasta420 on November 18, 2013 at 09:17 AM
Message Yes, the sensor is there and we closed the hood to ensure that it wasn't part of the problem.
The "car alarm" you're referring to is, I believe, the anti-theft ECU based on the location you provided - I did try that - no change.
There's a horn relay attached to the top of the anti-theft ECU - I did a couple of diagnoses on the pins, which seemed to be fine, but I did *not* test the relay itself (ran out of time).
Thanks for your response.. appreciate any other leads or suggestions!
-jb
