TwinTurbo.NET: Nissan 300ZX forum - Re: Car won't crank after 60K
Subject Re: Car won't crank after 60K
Posted by Rasta420 on November 18, 2013 at 9:17 AM
  This message has been viewed 242 times.
In Reply To Car won't crank after 60K posted by spicyZ on November 18, 2013 at 08:54 AM
Message do you have the car alarm sensor for the hood installed? I had same problem on my 90 NA --> TT swap car, had to wire tie the hood sensor so it was closed, fired right up after that. you can also unplug the car alarm from under the stock location on the inside passenger footwell, it is located up under the dash, and blue if I remember correctly.
Rasta420
