TwinTurbo.NET: Nissan 300ZX forum - Re: happening again(stumbling idle)
Subject Re: happening again(stumbling idle)
Posted by Cjw3 on November 17, 2013 at 2:45 PM
  This message has been viewed 118 times.
In Reply To happening again(stumbling idle) posted by lukzzkeeper(philly) on November 17, 2013 at 02:06 PM
Message Leaking Injector/Oring will let one cylinder run richer than the others, and will show up more at a low idle..
If you still think it's electrical, check the battery voltage at Idle.. if you have 13.2 or greater, you have NO problems.. if your down to the 12.8 range, you might have a voltage problem..
I'm not saying the voltage problem is related to your Stumble..
Cj
