TwinTurbo.NET: Nissan 300ZX forum - Get a friend to push the clutch
Subject Get a friend to push the clutch
Posted by Cjw3 on November 17, 2013 at 10:15 AM
  This message has been viewed 119 times.
In Reply To Re: Does the Clutch Engage close to the floor? posted by 90z2+2 on November 17, 2013 at 12:18 AM
Message and you watch it from underneath.. if the rod always moves the same time the clutch peddle moves, then it's LIKELY an internal clutch problem..
Ball Broken, or the Clutch disk or Cover is coming apart..
Clutch has to come out to check..
If the peddle moves for a a bit, then the clutch rod starts to move, it;s an external Hyd Clutch problem.. Master or slave or Air.
Cj
