TwinTurbo.NET: Nissan 300ZX forum - 370s would only be an improvement if...
xpwarrior
on November 16, 2013 at 7:16 PM
91 NA 2+2 Injector upgrade question
posted by Rasta420
on November 15, 2013 at 09:45 PM
you plan to go TT later. I used the bigger injectors on my NA for a while before going turbo and they worked fine but weren't any improvement over the 270s.
Rasta420
21:45:22 11/15/13
Nope...upgraded ECU is about it other than improved
jzack
17:51:11 11/16/13
Re: Nope...upgraded ECU is about it other than improved
Rasta420
18:45:22 11/16/13
370s would only be an improvement if... -
xpwarrior
19:16:43 11/16/13
Re: 370s would only be an improvement if...
Rasta420
06:21:59 11/17/13
It is not worth it, simply because the cost will not justify
CmyZ
22:39:33 11/19/13
