TwinTurbo.NET: Nissan 300ZX forum - You'd think so - I'm assuming the engine hasn't been
Subject You'd think so - I'm assuming the engine hasn't been
Posted by jzack on November 15, 2013 at 11:42 PM
  This message has been viewed 138 times.
In Reply To Re: 2nd on valve stem seals. Did it start doing this after posted by ariz on November 15, 2013 at 10:56 PM
Message run much with the new PCV valves, yes? If one of the valves had an issue (possible even if new) - would take at least 500-1K miles or so to start seeing it, doesn't happen really bad immediately (don't ask me how I know)....
Wonder if a piston ring, due to engine sitting, is sticking? Might want to run a compression check? Only other idea is a bad turbo on that side but this is an NA engine, yes? Going by your profile....
