TwinTurbo.NET: Nissan 300ZX forum - you did not blow a timing belt.. it still runs.
Subject you did not blow a timing belt.. it still runs.
Posted by Cjw3 on November 14, 2013 at 3:17 PM
  This message has been viewed 283 times.
In Reply To Sad, sad, sh!t times...... posted by blackomega on November 14, 2013 at 02:53 PM
Message Sounds like you just fubared the PS Pump, and the Belt came off, it took the other belts with it.. The Timing belt is WAY back behind the Shinny covers.. if you can see the timing belt.. BIG stuff is missing..
You wounded it.. strip all the shit off the front of the motor.. Radiator.. Fan.. belts.. get back to the Timing Covers.. with all accessory belts off.. start it and see if it clicks and bangs.. if it does, then likely your Toast!..
If it idles and runs well ( OK.. 30 seconds MAX.. got it? No water.) then Finish stripping the motor back and do the 120 K Service.. then put fresh rubber all around in the engine bay.. front and rear of the engine..
IF.. it really sounds bad.. Clicks and Bangs( Check the Oil for GOO.. ) then LIKELY you melted some things, and some sort of motor swap is necessary..
Cj
