TwinTurbo.NET: Nissan 300ZX forum - Take the time to remove the rear trim and
Subject Take the time to remove the rear trim and
Posted by doug8867 on November 14, 2013 at 6:14 AM
  This message has been viewed 550 times.
In Reply To new stock adjustable shock absorbers are not adjustable? posted by earthpunk on November 13, 2013 at 03:22 PM
Message inspect that the rear actuators are installed correctly before going any further. Eliminate the simple stuff first. Could be possible you did not get the strut pins fuly inserted in the actuators when you installed them in rear. Since you sit right in front of the rear tires, if those struts aren't being activated that's why it would feel like nothing is changing even if the fronts were working. Good luck.
