TwinTurbo.NET: Nissan 300ZX forum - No power to Coil Packs with new ECU.
Subject No power to Coil Packs with new ECU.
Posted by Retro-Cow on November 13, 2013 at 12:59 PM
  This message has been viewed 277 times.
Message So I just completed a plenum pull, 300 degree fuel rail install and nismo 740cc injectors. I also installed an Ash spec ECU but the coil packs don't get power.
It's getting fuel and air perfectly fine.
It also sparks and starts fine with the stock ECU but obviously runs rich.
Some info about the car that may help in determining the problem, it started as an automatic and I did a 5 speed swap on it. I used the "conversion" harness from z1 and I didn't wire the clutch to anything and I bypassed the starter relay. This may have something to do with it?
Also, the ASH-Spec ECU is a manual ECU and my stock one is the Automatic. Again it starts fine with the Automatic ECU.
Any help would be greatly appreciated.
