TwinTurbo.NET: Nissan 300ZX forum - Verify the MAF voltage outputs (compare to eachother)
Subject Verify the MAF voltage outputs (compare to eachother)
Posted by -Grimm- on November 13, 2013 at 9:37 AM
  This message has been viewed 252 times.
In Reply To Re: Of course it would matter. If it is running that rich, posted by GRNT300zx on November 13, 2013 at 12:40 AM
Message Or swap them out for new/borrowed units if available.
Also, if youre running that rich it is possible that the ECU is programmed wrong, sending larger injector pulses than it should be due to thinking it has smaller injectors.
If those check out, it could be timing related. Check your timing (cam timing, centerlines, and spark timing)
