TwinTurbo.NET: Nissan 300ZX forum - Na to TT power steering swap, getting ZERO p/s assist
Subject Na to TT power steering swap, getting ZERO p/s assist
Posted by Jkova300z on November 12, 2013 at 1:18 PM
  This message has been viewed 216 times.
Message So after installing the NA P/s conversion (new hi pres hose & sensor, all new oem return lines, J hose, NA reservoir, NA pump, proper belt) I have absolutely NO assist from the system.As far as I can tell, I removed all the old fluid from the system and rack before the conversion. Upon filling NA system, I bled it and it took about 1qt ATF. I couldn't find the entire NA system fluid capacity under search.
Pump makes no noise at all, groaning etc. The system did take the fluid when I turned the wheels to bleed. I still have the TT p/s control module. The Hicas light is one.
Feels like the pump is shot (it's a used pump but I was told it was in perfect working order)
When the TT/ Hicas system was in, it all worked. So the rack solenoid should be functioning.
