TwinTurbo.NET: Nissan 300ZX forum - Re: Cam timing (degreeing cams)
Subject Re: Cam timing (degreeing cams)
Posted by Doctor C on November 10, 2013 at 10:59 AM
  This message has been viewed 389 times.
In Reply To Cam timing (degreeing cams) posted by Doctor C on November 09, 2013 at 09:24 AM
Message I have figured out the problem.
The JUN Measurements of cam centerline are for the non adjustable cams.
The Tech at JUN says that all Z32 have the same cam centerline.
Now if we take in to account that the stock and BFE cams are in a retard position and will advance 10deg. When the VTC is active the previous base setting of the cam gears at 121 deg was only a
Few degrees off not the ten I thought they were.
The cams base timing on the VTC gear should
Be btw. 121 and 125 degrees.
