TwinTurbo.NET: Nissan 300ZX forum - Re: Adjustable Cam Gears?.. so were they set from Factory?
Subject Re: Adjustable Cam Gears?.. so were they set from Factory?
Posted by Doctor C on November 09, 2013 at 8:05 PM
  This message has been viewed 306 times.
In Reply To Adjustable Cam Gears?.. so were they set from Factory? posted by Cjw3 on November 09, 2013 at 12:55 PM
Message The BDE cams were set to stock.
Yes the block and heads were decked. But minimally. As is reflected by my exhaust cams being about 2.0 to 2.5 degrees off.
But the intake cams were off from cam centerline about 10 degrees.
That would be equivalent to about an 8mm deck on the block and heads.
It makes no sense. Unless my cams were not JUN 272 cams. But I just contacted JUN and all of their cams of the Z32 have the same centerline.
So it must be my cam gears.
I just did a leak down test to make sure I didn't bend a valve and all cylinders are less than 5%.
I am perplexed.
