TwinTurbo.NET: Nissan 300ZX forum - Throttle position sensor
Subject Throttle position sensor
Posted by ChristopherTheOne on November 09, 2013 at 11:21 AM
  This message has been viewed 334 times.
In Reply To Smooth idle when cold, loping idle once warm. posted by Marshall on November 08, 2013 at 02:52 PM
Message Check the wiring, contacts for corrosion, etc.
It's true the ECU ignores input from the O2 sensors at idle, but it determines whether or not to use "idle" controls based on the TPS value.
If the ECU isn't seeing the TPS as "fully closed," then it doesn't run the engine using idle settings...so make sure your TPS is actually signaling fully-closed when no throttle is applied.
