TwinTurbo.NET: Nissan 300ZX forum - to clarify..
Subject to clarify..
Posted by Cjw3 on November 08, 2013 at 4:06 PM
  This message has been viewed 279 times.
In Reply To ECU does not use O2's at Idle.. I've checked posted by Cjw3 on November 08, 2013 at 03:45 PM
Message What I've seen on the 16 bit JWT ECU is the O2's must be Flip/Flopping above and below the magic .45 volt range at the normal idle speed, then the ECU will settle into the 15* and 700 RPM idle mode.. IF the O2's do not flip flop ( Like a leaking Injector or Intake air leak) the ECU will not settle into 'Idle Mode' and will run fast idle and have the ignition advanced in the 20* range..
Cj
